Scheduled Standard Report export?
I'm wondering if anyone has had success scheduling an NXT Standard Report & exporting the resulting PDF to a local file? I've managed to confuse myself in the connector…
@Nicole Holt
I tried scheduling a Batch Report export and found it only created the download of the pdf and notified those that I shared it with that it was available for download.
It would be more helpful if it actually emails the report to those that I shared it with.Following this to see if anyone has had successful use of this feature. I would like to auto send a report on a daily basis.
@Nicole Holt
I have not done this, but I imagine the process should be relatively similar to Query API.- execute report job
- loop and check job completion
- get download link
- download and save file to SharePoint (can't be “local file” as flow doesn't have access to your “local drive”
@Alex Wong I tried that but didn't have much luck---that said, it wouldn't hurt for me to try it again when there are fewer distractions…
@Nicole Holt - Set it up as recurring in Power Automate, utilize the basic structure that Alex outlined. It's possible, I've done it.
@Austen Brown Aha! I was getting too complicated. Went back to basics and it works
And now that is one more thing checked of my monthly to-do list ?3 -
Thanks to @Austen Brown and @Alex Wong I went into Power Automate with clear eyes.
Sharing this solution in case it is helpful for others.1
- 361 Blackbaud eTapestry®
- JustGiving® from Blackbaud®
- 262 ResearchPoint™
