Power Automate - Create Constituent Note Types Error
a4e1b735ba6b511b82b097d89389af01-huge-sc
Has anybody been experiencing this type of error (incorrect note types in the 'Type' dropdown; is displaying address types in note types dropdown) in Microsoft Power Automate recently?
  • @Varun Mulchandani
    Yes! Only in one particular flow, but I have address types showing up instead of relationship types in one action. It will let me enter the correct entry as a custom value, so it seems to work, but it's consistently pulling the wrong table in, even after saving and closing the flow and going back in.
  • @Stacy Cope @Varun Mulchandani I haven't seen this behavior, and just tested the connector on a new flow and it worked as expected. I do see some note types related to address changes in the SKY Developer Cohort environment, but those are valid note types that show in the webview UI as well.
    I tested both old/new flow designers and it seemed correct in both. Just speculating, but it could be a bug with the new designer (maybe a caching issue). As you've noted, a workaround is to specify the desired note type as a custom value. You might want to open a support ticket with Blackbaud as well so they are aware.
