PowerBI Bar Chart - Creating a Data Label
Hello! I have a bar chart in PowerBI that has Opportunity Status on the Y-Axis. And a Measure -Count of Donor on the X-Axis. This is based on data from an Opportunity table and shows us how many donors are in each status.
I would like to incorporate an additional label to the right of the bar showing (Sum Amount Expected - Sum Amount Asked) to capture the range of the $$ impact at each status. I can pull in the $ value onto the X-Axis, but then it gets too busy and distracting. Example of the end result I'm looking for is also pasted below. Any ideas?! Thanks!
@Molly Glowacki Adding that I can add one data label within the Visual Formatting > Detail. this may be enough, but curious about creating my original request of a range.
- 361 Blackbaud eTapestry®
- JustGiving® from Blackbaud®
- 262 ResearchPoint™
