Append to String Troubles
I have a long list of flows to get up and running for 2025 and I thought I had started with an easy one…
I have looked through the community and found a couple of other references, but it's not quite making sense. I am happy to also bring this to the Power Automate User Group.
I'm trying to append to string multiple Custom Field Descriptions separated by a “,”.
I first did a Filter Array to isolate the Category I wanted.
Then looped through the results in hopes of appending to string so all entries were in one field.
Expression in Compose: item()?['codetableentry_value']
I'm thinking I'm not using the apply to each correctly.
As always, thank you.
@Sarah Homan
there is no need for the apply to each for the gift custom fields.- list custom fields
- filter array
- select
- select the “value” (don't need to specifically use the codetableentry_value, but you can) and don't “map” a field.
- set varaible (not append)
- join(body('select'), ‘,’)
@Sarah Homan
Screenshotsoverview of 3 steps make sure to click the “icon” circle in red to remove the “2 fields”. Only need ONE field, and then select “value” join(body('Select'), ', ')
@Alex Wong
It worked perfectly; I'll save this for future flows. Thank you0
- 361 Blackbaud eTapestry®
- JustGiving® from Blackbaud®
- 262 ResearchPoint™
