Query API- output format Rating field
I have a query that I'm pulling in by the Query by ID through the Query API. In the last week or so I have noticed that one of the Rating fields in the output of the query is coming back as a number not the actual description. I'm pulling it from Specific Sources.
For example, we have a rating description “M - $10,000” this is now appearing as a number 24653. All of them are like this.
I tried changing the formatting mode to Export but that didn't work. I'm also exporting it as a CSV. When I export directly it's fine so this must be something with the API.
Anyone else see this issue?
@Carol Grant
Have you check if 24653 is the table entries id for M - $10,000 ?0 -
@Alex Wong- I'm not sure how to check that. I know the field # of that field but I didn't know each entry had an ID. I looked in Tables in NXT and I don't see how I can retrieve that.
When I run the query in NXT it shows the same number. In DB View, it shows as the Text value. Maybe this is something they are working on?
@Carol Grant
Use this to get code table's idhttps://developer.sky.blackbaud.com/api#api=nxt-data-integration&operation=GetCodeTableList
then use this to get table entries (id and description)
https://developer.sky.blackbaud.com/api#api=nxt-data-integration&operation=GetTableEntriesList
- 6 Blackbaud Community Help
- 33 Blackbaud Impact Edge™
- 19 PowerUp Challenges
