HTML Table Formatting Won't work
For a few years I've been wanting to put some CSS Style into my HTML tables. I have read through all of the posts in Austen Brown's post here:
and I've tried Ben Regier's suggestions for adding html and head to the body. Can anyone see what the issue is here? I'm using Outlook. The CSS Style is something I built through the free tool that Austen mentioned.
<html>
<head>
<style>
table.paleBlueRows {
font-family: Arial, Helvetica, sans-serif;
border: 1px solid #FFFFFF;
width: 350px;
height: 200px;
text-align: left;
border-collapse: collapse;
table.paleBlueRows td, table.paleBlueRows th {
padding: 3px 2px;
table.paleBlueRows tbody td {
font-size: 13px;
color: #215ACC;
table.paleBlueRows tr:nth-child(even) {
background: #D0E4F5;
table.paleBlueRows thead {
background: #215ACC;
border-bottom: 5px solid #FFFFFF;
table.paleBlueRows thead th {
font-size: 17px;
font-weight: bold;
color: #FFFFFF;
text-align: left;
border-left: 2px solid #FFFFFF;
table.paleBlueRows thead th:first-child {
border-left: none;
table.paleBlueRows tfoot td {
font-size: 14px;
</style>
</head>
<table><thead><tr><th>Gift Date</th><th>Donor</th><th>Donor Codes</th><th>Class Agent</th><th>Was Gift Anonymous</th><th>Gift Amt</th><th>Fund</th></tr></thead><tbody><tr><td>06/23/2024 </td><td><a href=http://renxt.blackbaud.com/constituents/11111>Name 2023</a></td><td>Undergraduate Alumni</td><td> </td><td>False</td><td><a href=http://renxt.blackbaud.com/gifts/>$15.00</a></td><td>Middlebury Financial Aid Fund</td></tr></tbody></table>
</html>
This is all in one compose where I put the output of the cleaned up HTML table into the body of the Compose- CSS Style.
My email has the outputs from the Compose CSS Style.
I've also seen emails where you put both the CSS Style in the email along with the outputs from the Cleaned up HTML table.
I do get an email but nothing is formatted.
Carol
@Carol Grant
there are a few issues:- From strictly HTML/CSS perspective, your <style> tag reference TABLE element .paleBlueRows class, but you are not using paleBlueRows class in any <TABLE> element. so none of the style is actually used in any table.
- From Email HTML/CSS perspective, you cannot use class definition for styling. There are a lot more restriction to CSS when it comes to sending HTML email.
So meaning, you need to do
table {
width: 350px;
height: 200px;
text-align: left;
table td, table th {
padding: 3px 2px;
table tbody td {
font-size: 13px;
color: #215ACC;
table tr:nth-child(even) {
table thead {
table thead th {
font-size: 17px;
font-weight: bold;
color: #FFFFFF;
text-align: left;
table thead th:first-child {
border-left: none;
}table tfoot td {
font-size: 14px;
}notice I removed all the .paleBlueRows
I also don't think nth-child(even) works in HTML email.
@Alex Wong- thanks Alex! That worked, I was trying out some custom colors in the free tool to see how fancy I could make the table. Now I know not to try that. ?
Thank you for getting it to at least have some color, now I definitely need to fine tune it.
@Carol Grant
from a low-code perspective, there are limited things you can do with styling the email.However, if you got someone in your org that handle your website and/or email campaigning, you can get some advanced styling from them to use in your email.
As for the table itself, not worth the effort, BUT if you really want to, you can make it visually more appealing by adding each row of table directly in the apply to each. (meaning, instead of adding append to array variable the object that has the data column:
“constituent id”: “1234”,
“name”: “john smith”,
“gift date”: “1/1/2024”,
“gift amount”: “$1000”
}and then use create html table on this array. You can use a string variable that store the HTML for the table row and customize however you want it.
- init string variable with
- <table border="1" width="100%" cellspacing="0" cellpadding="3">
<thead><tr><th>RE ID</th><th>Donor Name</th><th>Gift Date</th><th>Gift Amount</th></tr></thead>
<tbody>
- Apply to each gift
- gather info as you need
- append to string variable with
- <tr>
<td style="whateverstyle">1234</td>
<td style="whateverotherstyle"><a href="https://renxturltoconstituent">john smith</a></td>
<td style="anotherstyling">1/1/2024</td>
<td style="text-align:right; color:green">$1,000</td>
</tr>
- <tr>
- append to string variable to close the table body and table tag
- </tbody>
</table>
- </tbody>
notice I made the $1,000 dollar amount green and align to the right which mimics what excel would have the currency value.
Also, you can use this expression iterationIndexes() to determine if you are in the “odd” or “even” data row in the loop for banding the row background: https://learn.microsoft.com/en-us/azure/logic-apps/workflow-definition-language-functions-reference#iterationIndexes
if you have condition in your gift loop that some gift doesn't go on the table, then you can use a toggle variable that toggles even and odd for banding.
obviously this will require a bit more HTML and CSS knowledge, but for a day when you feeling artistics on your email. =D
1 - init string variable with
@Alex Wong- thank you for the great tips! I may dig into this when I'm feeling artistic. ?
- 6 Blackbaud Community Help
- 33 Blackbaud Impact Edge™
- 19 PowerUp Challenges
