Sharing my Power Automate template: Overdue Action Audit
Description:
This flow will pull a list of overdue actions from RENXT and send an email requesting the fundraiser update the actions.
Required connections:
Blackbaud Raiser’s Edge NXT Constituents
Blackbaud Raiser’s Edge NXT Interactions
Office 365 Outlook
Microsoft Teams
Suggested skill level:
Beginner
Configuration details:
Begin by creating an action list in RENXT that is filtered by:
- Action Status = Past Due
- Action Date = (your choice). We use “Last quarter.”
- Fundraiser = (your choice).
- Note: I’m working on a version that will dynamically pull in the fundraiser assigned to the action. I will share an update when that is completed.
Download the flow:
- Visit Getting Started in the Blackbaud community if you need support.
Set up the Flow
- Update the recurrence trigger to suit your organization's schedule.
- This flow is set to run on the first of every month at 8 am.
- In the “Select actions list from RENXT” step, Update the Action List
- Link the list to the dynamic action list you created in RENXT.
- Update the “Append to information to array variable” step.
- Update the “Email about Overdue Actions” step
- Replace the email address in the “To” field.
- Update the email body as needed.
- Replace the email address in the “From (Send as)” field.
- Replace the email address in the “Reply To” field.
- Disable static result
- Update the “Post message in a chat or channel” step.
Category:
Automation, Data Management
Note:
This flow incorporates an error-handling method presented at the 2023 bbdevdays by @Alex Wong. You can learn more at: https://youtu.be/WbUvc50Or-E?si=RuoQ9dVpWnqa9Lgc
OverdueActionAudit-BlackbaudTemplateShowcase_20240523143342.zip
Here’s the promised update to this flow! The email summary now includes the assigned fundraiser in the action summary table, and the flow has been enhanced to dynamically send the summary directly to fundraisers with overdue actions.
2
