Best Way to import In-Kind Form Responses
We get a lot of In-Kind donations and are looking to transfer from a paper form to a Microsoft Form. I have created the Form and have the results go into an Excel spreadsheet.
I am looking for recommendations on the best way to get the In-Kind gifts into Raiser's Edge.
Can this be done using Power Automate?
  • Austen Brown
    Ninth Anniversary Kudos 5 Name Dropper Participant
    @Susan Fioribello - This is possible, you don't even need to add the information into a excel doc first - you can have the flow run off of a new entry through the form and directly add the gift to RE. This will take some experimenting on your part - I'm not sure if there are any templates in the showcase that cover a use case like this. Looking purely at the available APIs and actions within the connectors…
    If you want gifts to go into a batch first, you can use an HTTP call to “Create a gift batch” and the “add a gift to batch” action in the “Blackbaud Raisers Edge NXT Gifts” connector. This would be a great way to group gifts by day, if that is apart of your normal process.
    Otherwise, you can add gifts directly to the system using an HTTP call to “Create a gift”.
    @Alex Wong - Any additional thoughts?
  • Alex Wong
    Alex Wong Community All-Star
    @Susan Fioribello
    When using Microsoft Form, the submission is automatically entered into an excel file on sharepoint/onedrive depending on how you created the MS form. This excel file you can “ignore” unless you want to “batch”.
    There are a few ways you can do this depending on your choice:
    • automated per submission on MS form where gift is directly created
      • create gift directly using create gift endpoint
      • requires you to have a lot more info answered on the MS form (i.e. fund system id)
    • not automated per submission on MS forms
      • using the excel file that MS form submission goes into, use a “manual” trigger when you want to do it (or a schedule trigger to do it at night).
        • one of the action you will do in the flow is to create a gift batch
        • then you will read through all submission in the excel file and batch them into the new gift batch created.
        • automation should “mark” the submission as completed with a status column added to the excel file (and potentially even the web batch # created into a batch column in the excel file)
      • this way you can review the batch and enter any missing information you like before approving the batch
      • another benefit is creating a gift in batch has less requirement for field being filled out as you can do that in the web batch.
