Sharing my Adaptive Card Power Automate Template: BioOrg2
- Description:
Typically speaking, information available in SKY API is also available in the WebView. However, that's not always the case. This Adaptive Card based flow shows an example of surfacing information that is "API-only" as a custom tile.
It is originally inspired by the information that's available in either the Individual Bio 2 tab or the Organization Org 2 tab in Database View, hence the name. However, for Orgs, it does include Matching Gift information that's on the Org 1 tab.
It does not contain all the pieces of information that's available on those tabs either due to that information not being available in the API (at the time of publication) or already available elsewhere in the system.
This one flow handles both Individual and Organizations by branching depending on type of Constituent.
This also takes a further approach about avoiding the use of Variables unless necessary to aid in portability and section reuse. In this case, the content of each branch is assembled in a Compose action. Using the ‘coalesce’ function to render in the Response which one actually has content, rather than loading it into a variable.
- Required connections:
Blackbaud Raiser's Edge NXT Constituents & SKY Add-ins
- Suggested skill level required to use this template: Beginner
More details at https://github.com/glenhutson/BlackbaudCustomizations/tree/main/Raiser's-Edge-NXT/BioOrg2
Individual Example:
2da885236c057bc2837222fd15004ced-huge-bi
Organization Example:
99faa4f8067988aa4e26c46afcf75bf1-huge-or
