Removing characters from an array variable
Hi There,
I am wondering if anyone knows of a way to remove the [" and "] from entries in an array.
I have a flow that pulls in all the actions that are coming up in the week ahead and emails them in a table. Two of the columns I use are Action Assigned To and Assigned Solicitor (Relationship Manager). I am able to pull in the names, however, because they are string values, they output like: ["Name1","Name2"]. I'd like it to just be the name with out the [" and "].
Here is an example of the output:
e34044f17de63c2918211d402341451e-huge-im
  • Alex Wong
    Alex Wong Community All-Star
    @John Hazelwood
    you can use a join expression to join an array of string with a separator.
    join(dynamic_content_of_array, '; ')
    this will join the array of names (i.e. ["John Smith","Jerry Steinfeld"]) with a semi-colon and space characters into John Smith; Jerry Steinfeld
  • @Alex Wong
    Thank you Alex!
    I tried the join, but feel like I don't have the correct name for the Array, as it throws an error. Here is what I put, did I do it wrong?
    ae26ad24551062e9de6641798a7e9565-huge-im
  • Austen Brown
    Ninth Anniversary Kudos 5 Name Dropper Participant
    @John Hazelwood - When creating the expression…
    • start with typing in "join()" into the expression window,
    • put your cursor between the parenthesis,
    • then click on the “Dynamic Content” tab,
    • under the variables section click on the array you want to use,
    • then click on the “Expression” tab,
    • go to then end of your expression and add the additional detail for the separator symbol,
    • then click “OK” to paste the expression in the action.
  • Alex Wong
    @John Hazelwood
    expression to access the variable is not correct. Use:
    join(variables('RelationshipManager'), '; ')
    join(variables('Action Assigned To'), '; ')
  • Thank you, both!
