Event Attendee Columns - any way to edit
Our event coordinator is asking: Is there a way to change the way the attendees are listed in the events in NXT? All the sudden rather than having the “host of/guest of” listed in a separate column, they are grouped underneath the attendees. It is incredibly difficult to read, is there a way to revert to the way it was? She has looked at the column settings but hasn’t found a way to make that change. Any tips?
Hi @Ellen Stack, thank you for the question.
At this time, there isn't an option to separate the columns in the UI, but they are still separate in the participant list export.
The goal for the change was to reduce the real estate needed to see relevant participant information so users wouldn't have to scroll to the right as much, now that we offer a Fees column.
Hearing that the Name and Host/Guest information in a single column is difficult to read is valuable feedback. Would you be will to add this as a suggestion on our idea bank? That way people can vote on it and we can evaluate if an update is needed.2 -
@Kimberly Hammer, will do so. Thank you
The suggestion to vote on is here - just voted myself as I was recently importing participants for my colleagues. and it is indeed tricky to read!
