OneCause and Raiser's Edge integration
Hello! We currently use OneCause for all our events and are searching for a way to integrate the OneCause data seamlessly with the Raiser's Edge database, preferably in real time. Does anyone know if this exists?? Thanks in advance for any info!
  • Austen Brown
    Ninth Anniversary 1,500 Likes 1000 Comments Name Dropper
    @Jane Miller - Welcome to BB Community! I recommend you check out Importacular - it is a third-party tool that aids in importing data into RE. While it is not “real-time”; it makes the import process much eaiser.
  • @Austen Brown Thank you for the welcome! Yes, thanks, we've explored Importacular but it doesn't seem very user friendly. The mapping seemed to take longer than just importing the gifts via RE. What was your experience, how have you found working with it?
  • @Carrie Aranda Thank you so much for sharing your experience with Importacular. It gives me hope! The main place I'm running into trouble is having no unique identifier (i.e. Constituent ID) included in the import data from One Cause. How have you been successfully addressing that?
  • @Carrie Aranda Thank you so much! This is very helpful. I will explore your suggestions and will definitely take you up on your kind offer of direct assistance should it be needed. Thanks again!
  • @Austen Brown
    We're brand new to OneCause and our event(s) has ticket sales, CC fees, and wait staff tip. Would Importacular help in sorting all these so that I import the total gift amount (from event) into RE and then have the Receipted amount be the Charitable amount?
  • Austen Brown
    @Tracy McLuskie - I recommend reaching out to the folks at Importacular to inquire about this.
  • @Tracy McLuskie
    Hi Tracy, I recently finished importing all of our OneCause data into RE. It is a step-by-step process using good ol' RE imports, and a little tedious, but it can be done.
    In OC, in Reports - Exports - there are exports set up to use for creating the import spreadsheet for RE DBV. (Just be sure all of your Constituent IDs are entered in OC before you begin!) You can add a column for the receipt amount. I then did additional imports to add benefits and solicitor information to each category of gifts that were imported.
    I referenced Knowledgebase article 37528 - instructions for import directly to gifts. I have a series of queries that are then used to check the imports. I'm happy to share more about my process as needed.
  • @Jane Miller
    I was just wondering if you ended up using Importacular as your import tool while using onecause and RE? My Foundation has purchased oncause for our events and I am trying to find any info I can to try to set us up for seamless data integration.
  • @Jennifer Kluh
    Hi! I ended up following Carrie Aranda's advice in a previous reply to this thread and using RE export, OneCause import then the reverse after the event. It took some setting up, but it worked well!
  • @Jane Miller
    Thank you for this!!! Always an adventure
  • @Elaine Buescher Hi…I am totally new to using and need to get some gifts from BidPal to RE. I am trying to use the importacular plugin… any help you can offer would be much appreciated.
  • @Marisa PhirangeeGentles, we don't have the Importacular plug-in. I used native RE imports. Looks like @Carrie Aranda is the best source to consult on this topic. Good luck!
  • @Jane Miller
    could you explain please a litlle bit more how you sorted tha out?
    We have switched to Onecause for our fundraising event software and I want to make sure we can import those transactions & constituent info into Onecause.
    I mean we will need to export from Onecause and import into blackbaud after the gala.
  • @Elaine Buescher
  • @Mariana Escobar, send me a message, and we can connect off line. I can send you my notes.
