Recurring Gift
Using the Connector I can see the fields but no data is retrieved and ideas
@Phil Bell
Do you receive any errors? Can you share a couple screen shots of what you are seeing?0 -
@Ashley Moose
No errors when I connect to the Gift it shows the fields see ScreenShot.docx But no data although I know these are Recurring Gifts.0 -
@Phil Bell Thanks Phil! Unfortunately I'm not a Power BI expert (I focus on Power Automate) but try taking a look at
or searching the community for other ‘missing Power BI data’ related posts. If that doesn't help, then definitely reply back here as I'm sure one of our other Power BI power users may be able to help.
Hey @Phil Bell, the Blackbaud Power BI connector uses the Gift List endpoint to create the Gift table you see in Power BI. The schema, according to the API documentation, lists all of the recurring payment information as part of the returned values (which is why it's built into the structure of the Power BI table). However, I've tested the endpoint with several recurring gifts and recurring gift information does not get returned.
I've created a post in the SKY Developer community to see if there's an issue with the endpoint itself. If there's any update, I'll come back to this post and update it
- 6 Blackbaud Community Help
- 33 Blackbaud Impact Edge™
- 19 PowerUp Challenges
