Dynamic suggested donations
Does anyone here use a process that asks constituents to donate at a certain level based on their “Next ask amount” in the Ratings area of RE?
It's something we're considering at my org, but I haven't had time to do much research yet - I don't even know if that info is available in the connector/API. Thought I'd check here first!
  • Dariel Dixon
    Dariel Dixon Community All-Star
    Seventh Anniversary Kudos 5 PowerUp Challenge #3 Gift Management Name Dropper
    @Ben Regier In regards to mailings, we've used products like AskGenius to determine suggested amounts that we print in our appeals, but those values are not kept in the RE ratings. We have them created specifically for the mailing as they have a tendency to change quicker than the RE ratings refresh.
  • @Ben Regier
    I like where you're going with this, but the new RE NXT donation forms will continue to be optimized including adaptive fundraising like ask amounts and sustainer upgrades.
    Have you enabled any of the native features here and coming soon?
  • @Ben Regier
    If you can't access the data through the connector, you might want to segment by ask amount range/ask ladder via lists (if “Next ask amount” > X, then…) and then either run different flows for each or use Condition branches inside the same flow.
    Depends on your use case. What are you trying to achieve?
    Louis Diez
    joindpp.org
    Fundraisers Band Together to Find Practical Solutions to the Giving Crisis (Chronicle of Philanthropy)
