Power Automate - SFTP Connection Issues
It seems when I try to use this in my flows I always get Bad Gateway. I don't have anything scheduled using it yet but each time I open the flow I get this. I just used it 2 days ago to test the flow.
I wouldn't say anything but it takes me at least 5-6 times of re-entering the same information to connect. Sometimes I give up and go back in the next day. I try multiple times in Data- Connections also and it looks good but back in the flow I still get this. I refresh the flow, etc.
fc0779b3bf0fba13d9e4b0b840a867a0-huge-im
I am putting in server address, username, password and then this:
c28c497300e1c91dc8f5003d19ce19f8-huge-im
Any help to make this easier- I'm trying to copy files from Queue into Sharepoint.
Carolyn
  • @Carolyn Grant
    I am getting annoyed with the same experience. Just wondering if it is on the Blackbaud side or Microsoft?
  • Glen Hutson
    Glen Hutson Blackbaud Employee
    Tenth Anniversary Kudos 3 Name Dropper Participant
    I'm seeing as well that sometimes it works and sometimes it doesn't and the Power Automate action doesn't give a lot of details I can use to diagnose and (if needed) pass along to others. I've been evaluating a number of interim solutions but still haven't zeroed in on one I like better. Here are two for consideration:
    1) Potentially wrap that connection into a “do until” to force additional retries
    2) And/or add parallel branch that only triggers on failure of the SFTP connection to send an alert to an internal contact.
  • @Glen Hutson
    Thanks Glen- I wonder how others get it working smoothly? I wanted to use it to copy my files that were run in Queue to my Sharepoint folders. I'll keep these in mind.
  • @Glen Hutson I don't usually have issues with the connection running as part of my flows, but if I need to edit my flow at all it may take a few tries in and out of the flow and re-adding my password to get it to save. It is not an issue of the regular SFTP password re-set either, I have those as a calendar appointment to update. Anyway, seems to be something with the Microsoft connector maybe?
  • Hi @Ben Lambert - Can you offer any help with trying to access FTP via Power Automate? I constantly get Bad Gateway with the same error above: "message": "An existing connection was forcibly closed by the remote host\\r\\nclient
    ce1fe6b2cf37fc0a44a85b06454e6b98-huge-im
    Retries don't seem to help, it's the minute I add this to my flow. Thanks @Glen Hutson for that suggestion but didn't work for me.
    Are there settings that need to change? I refresh the page to see if it updates and it doesn't.
    I can access this via WinSCP using the same credentials and it works fine.
    Thanks for any help- I really want to solve this.
    Carolyn Grant
    Middlebury College
  • @Carolyn Grant
    @Ben Lambert @Glen Hutson I just looked and does it matter which of these connectors we use? I have been using the SFTP - SSH as that was used one of the overviews I saw, but if we should be using the other one hoping maybe that is the issue?
    8ebfcc2690b80588e7475eec5fcdfd4a-huge-im
  • I'm afraid I don't have much experience with or knowledge about the SFTP (or SFTP - SSH) connectors, so maybe someone else will be able comment. According to the docs, the SFTP connector is deprecated so I believe the SFTP - SSH connector should be used.
  • @Carolyn Grant I think there is an issue with the 45 day password reset/rotate. I think if you miss the timeline (I saw in another post 45 days) then you have to recreate it. It is super frustrating.
