Power Automate - Search for a Constituent action
Running into an issue with using the Search for a Constituent action. I'm pulling data in from a third-party source so it sometimes includes spouses that are not full constituent records. When I use their name in the Search action, it always returns 0 results. But, it I use their NXT environment ID in the Get a Constituent action, it will return their record.
Anyone else run into this?
@Matt Thacker can you provide more details on this (specifically, I'm not following what you mean by "use their NXT environment ID in the Get a Constituent action")?
Hey @Ben Lambert,
If I use the Get a Constituent action and use this ID, I get the following response:
But if I use the Search for a Constituent action for the same person, but using their name, it always returns an empty array
@Matt Thacker thanks, that helps! The ID you have circled is the “system record ID” which under the hood is the system-defined primary key on the relational database table that stores constituent records. My confusion was how you used the phrase “environment ID” which has a different meaning - that ID is essentially a tenant identifier that separates Blackbaud customer “database” A from Blackbaud customer “database” B - I'm simplifying a bit but hopefully you get the idea,
I believe what you are seeing is the nuance around “non-constituent” records (a very old and often-debated concept within RE). In order to support records with many of the same fields and related data in other tables as a constituent, the constituent data structures were re-used and a flag was introduced to designate whether the record was a full-constituent or (for example) just a relationship or (another example) an event participant guest.
The “Get a constituent” action (and the underlying GetContituent endpoint in the SKY API) can be used to get details for both constituent and non-constituent records. But the “Search for a constituent” action (and the underlying SearchConstituent endpoint in the SKY API) only returns constituents - it doesn't (currently, afaik) return non-constituent records.
In your screen shot, notice the is_constituent: false property on the response which designates that Cindy is a non-constituent, so that record won't be returned by the search action.
- 6 Blackbaud Community Help
- 33 Blackbaud Impact Edge™
- 19 PowerUp Challenges
