Campaign ID format in Gift List
I am trying to create a custom gift list, but the flow doesn't like my Campaign ID Format. We use letters, vs. numbers - not sure if that matters. Anyone know what the correct format is? Do I need an expression here or just a list?
Hi @Reuben Schmitz ! Are you using the System Record ID of the Campaign? That is the number found in the URL in web view, not the Campaign ID defined by your organization in database view. For example, the campaign below has a System Record ID of 1.
I was not - the instructions indicated Campaign ID, not Campaign System ID - will give that a try - can also find this in the Properties in Database view it appears.
That worked just fine - thanks again for pointing this out.
Hi Reuben,
Thanks for pointing this out - we'll update the description text in your screen shot to better indicate that these values are “system record IDs” not “user-defined identifiers”.
2
- 6 Blackbaud Community Help
- 33 Blackbaud Impact Edge™
- 19 PowerUp Challenges
