Filtering specific Gift Custom Fields
I have spent most of today working on this, and still have a problem.
When I use the filter above the “apply to each”, I see the output I want.
1c5d3eff09a597b09d277360bbef480e-huge-im
When I put the same filter into the “Apply to each”, I see no output and the filter doesn't work.
95768bae66383eaf465c9181363da115-huge-im
This is how the flow is set:
54b8e0e72a1650f3dc18ed327a511e3c-huge-im
I can filter using just the filter, but can only do that once. I need to have two different sets of gift attributes to display. I used the filters this way and it worked once, then the second Repeating Section was no longer recognized in the word doc in the flow. Any thoughts as to where I might go next to do this?
This is from the word doc - again, it works once, then the second Repeating field will become disabled.
803908028bf92783bbe2179631757179-huge-im
NOTE: This is what it should look like - the two Gift Custom Field categories are Designation and PTDesigTable Driven, displaying the value and comment (%) of each (from the first time when it worked). I assume there is a different way to do this?
9947da490f250ef1e1413dff11b1eaf3-huge-im
  • After much trepidation, trial and error, I figured out how to do this. I used two methods here to get specific gift attribute Categories to display in two separate Repeating Section tables in Word:
    5ebb7d8335169c7763180776beffdac0-huge-im
    b23b5c87813db155428072f11f47fdad-huge-im
    938f500ebd309bef25446a9846cc22a0-huge-im
    I found that you can't use a filter for a Gift Custom Field if in an Apply To Each. For the first one (above), I used the filter array and ensured that the Descriptions I used in the Plain Text content control merge fields were exactly the same as found in the Gift Custom Fields. For the second (below), I learned that you can't use those same fields again as Word will not recognize the second Repeating Content Table. Finally, I tried this and it worked find. Note that the Value1 and Comment 1 labels are different and work using the Select statement.
    3cc9cb2d4611f5749094d09a1cf1bd77-huge-im
    I believe a formula might also work - Matt T was going to give that a try. But as this worked for me, I went with it.
