Save the Date for Events
Has anyone found a way to track on the event record that a “Save the Date” was sent? Thanks in advance for your help.
  • Do you want to track it on the event or on the participants? If on the event, you can put it in as an event action. If on the participant, you can add it as a participant attribute.
  • Hi Tina, Thanks for such a quick response. I would like to track it the participant. Currently, we're using a constituent action to tracking STD's. I'll give the participant action a try. Thanks again.
  • Dina, a participant attribute is fine if you record all invitees in the Event record. Some people prefer only to track actual registrants in the Event, so they can see true engagement at a glance.
    If that's the case, you may consider recording STD's and invites on the constituent Appeal tab. By setting up an Appeal to correspond with your Event, you accomplish three goals: it allows you to post Event income to an appeal for better database revenue tracking; the Appeal record also has full functionality for “number sent” and constituent “response”; and you can better pull data on how many total mailings your constituents are receiving if all mailings are recorded in one tab.
  • Samantha McGuin
    Samantha McGuin Blackbaud Employee
    Tenth Anniversary 100 Likes 100 Comments Name Dropper
    You can also use the Invitation Status field for this on the Participant, which has an Invitation date that you can use to track the date your Save the date was sent.
