BI Connector
I followed the instructions on creating a Power BI Connector for Raiser's Edge. When I went into BI desktop I got a message “The following connector has not been certified, and we are unable to verify that it is secure to use” and then it lists Blackbaud. I can only click on ok and when I go into get data, the Blackbaud connector is not there to choose from. How do I get past this so I can use the connector?
You need to allow uncertified connectors for it to work. If you're in Power BI desktop, go to File → Options and Settings → Security, you can check “Allow any extension…”. Close and reopen the desktop application and go to Get Data and ‘Blackbaud’ will now be an option.
Thank you that worked!
- 6 Blackbaud Community Help
- 33 Blackbaud Impact Edge™
- 19 PowerUp Challenges
