Dynamic File Schema Error
Hi All,
I am trying to get the “Simple Merge Webview List” template set up in Power Automate and I'm getting the following error. This happens after pointing to my merge doc in SharePoint. Has anyone seen this error before? What is this telling me and how do I fix it? Thanks in advance for your help!
I'm guessing this is related to pointing the action to a new template file. The fields in the new file may be the same, but the schema id is different.
I'd populate the small fields above ("AddressLines", “GiftDate”, etc.), and then delete everything in the big dynamicFileSchema box. See if you can save after that.
Just a guess.
I arrived at that solution, too, and can confirm that it works. Thanks for the post!
- 6 Blackbaud Community Help
- 33 Blackbaud Impact Edge™
- 19 PowerUp Challenges
