Using the Webhook API to trigger flows in Power Automate
Hi everyone,
During my session at #BBDEVDAYS last week, some of you asked about how the Webhook API can be used in Power Automate as triggers. I explained that Power Automate does not natively support webhooks adhering to the CloudEvents specification, however, there is a workaround that I can share here.
Below is an example of a simple flow that sends an email notification when a new gift is added in RE NXT.
Define a flow using a Request trigger and set the method to OPTIONS:
Implement the CloudEvents handshake by returning a 200 with the appropriate header (WebHook-Allowed-Origin: eventgrid.azure.net) using a Response action:
Save the flow to get the URL, and then manually register that URL as a webhook through the Webhook SKY API:
POST https://api.sky.blackbaud.com/webhook/v1/subscriptionsHTTP/1.1
Host: api.sky.blackbaud.com
Content-Type: application/json
Authorization: <your access token>
Bb-Api-Subscription-Key: <your subscription key>
"webhook_url": "<the URL of the flow>",
"event_type": "com.blackbaud.gift.add.v1"
(make sure to specify the event_type that you’re interested in from the Event Types reference page)
Our API will send the OPTIONS handshake request (to your flow URL), which will respond with a 200 and the subscription will be created. Of course, the flow won’t be able to handle actual POST webhook events yet because it’s only coded to handle the OPTIONS handshake. We’ll handle that next.
- Update the flow and change the method to POST.
- Paste in the CloudEvents JSON schema into the request body to enable Power Automate to interpret the webhook message properties. You'll need to make sure this schema includes the properties that are in the data object for the specific event-type you're subscribing to. For example, if the event type provides an id, you can paste this in:
"type": "object",
"properties": {
"type": {
"type": "string"
"specversion": {
"type": "string"
"source": {
"type": "string"
"subject": {
"type": "string"
"id": {
"type": "string"
"time": {
"type": "string"
"data": {
"type": "object",
"properties": {
"id": {
"type": "string"
If the event type includes the constituent_id, you can paste this in:
"type": "object",
"properties": {
"type": {
"type": "string"
"specversion": {
"type": "string"
"source": {
"type": "string"
"subject": {
"type": "string"
"id": {
"type": "string"
"time": {
"type": "string"
"data": {
"type": "object",
"properties": {
"id": {
"type": "string"
"constituent_id": {
"type": "string"
}It should look something like this:
- Now you can delete the Response action (since it’s no longer needed) and implement whatever interesting workflow logic is desired within the flow – it will be triggered when events happen in the Blackbaud system. Here's an example Flow to send an email when the gift is added. Note that I have to make additional SKY API calls to ge the Gift details and the Constituent details to put in the email. I'm also including the properties from the webhook payload so you can see how to use them. One gotcha is to make sure you reference the right “id” property, it will be the one shown in the tooltip:
That should be it! Let me know if you manage to get it working.
What is the best way to obtain Authorization access token in Power Automate?
Hi @Alex Wong, in case you haven't gone through the initial setup steps already, here is the documentation:
This will take you through the process of connecting the Microsoft Power Platform for Raiser's Edge NXT app from the Marketplace and how to get it set up in Power Automate.
To make the Webhook API call to create the subscription, you can use something like Postman or the SKY API Console. However, the be aware that when creating subscriptions with the SKY API Console, the subscription will belong to the SKY API Console, which means the subscription will be canceled if it gets disconnected from your Blackbaud environment.
I hope that helps!
Hi, I have done all the setup already and able to use the actions under the Blackbaud Raisers Edge NXT connector. That is not what I am having issue with.
What I am trying to do is use Power Automate HTTP request to call the RESTful API of SKY API. (for example below, trying to get all phone types using GET method of HTTP). What I am not able to understand is how to generate the Authorization token that I need to pass into the yellow highlighted in the image below.
Hi @Alex Wong, you'll need to generate the Authorization access token through some other means outside of Power Automate. The simplest way is to probably use Postman which will give you a callback URL and a place to put in the other query parameters needed for the OAuth 2.0 process. This will require you to register an app on the SKY Developer Platform to get the clientid and clientsecret, and connect the app to the environment you wish to make the API call to.
We have a tutorial for the OAuth authorization code flow that explains the process for developers. The Power Automate connector for RE NXT handles this for the APIs supported by the connector.
@Alex Wong, it's possible to connect to the API using the HTTP action, but it will be a lot of work, especially since your credentials expire after a set amount of time and all of those fields will have to be updated!
If you need to access an API endpoint that is not already included in Blackbaud's premium connector, a much easier way of doing it is building a custom connector. Once you have the authorization set up there, it will automatically refresh your authorization token whenever it expires.
We've been using webhooks in Power Automate for a while now, and they are very useful! There is one thing to watch out for, though.
All Connectors in Power Automate have throttling limits associated with them. These are rules that say, for instance, “You can only use this connector 300 times every 30 seconds.” If you try to use it more often then that, it will fail.
To see where the potential problem lies, let's say you create a flow that will email you when a constituent is deleted. Let's say you use an email connector that lets you send 100 emails every minute. Then let's say you go do some database cleanup and bulk delete 500 records all at once.
This will create 500 runs of your flow in Power Automate, and will quickly exceed your limit of 100 emails per minute. Most of your runs will fail.
Your best tool in this scenario is Concurrency Control. If you go to the trigger and go to settings, you can control how many flows can be run simultaneously. If you set this to one, it will only process one flow at a time, which will significantly slow down the number of emails being sent out, and will hopefully be enough to keep you within your limits.
Trigger settings Concurrency Control If that's not enough to keep you from hitting your limits, you can add a delay to your flow so that each run will take longer to complete.
The main thing is that if you build a flow using a webhook, you need to make sure you know the throttling limits of each connector that the flow uses, and use concurrency control and possibly delays to make sure you don't hit it.
It's not a hard problem to solve, but it's an easy one to overlook!
Hi,
I was able to follow the tutorial to have new gift trigger my flow. Thank you.
I do have a question though, is there somewhere on developer portal that shows me all the webhook that was provisioned?
You might be looking for this.
Webhook API resources - Blackbaud SKY API Developer Portal
The Endpoint Reference is very useful as well. You can use it to view all of your webhook subscriptions.
- 6 Blackbaud Community Help
- 33 Blackbaud Impact Edge™
- 19 PowerUp Challenges
