Please add Update to Email Comment field
Hello,
When updating the Power Automate connector please consider allowing us to update the comment field on a donor's email record
We run some validation scripts on email addresses and output the results in the Comments field. It doesn't look like the Power Automate connector gives us that option currently:
This would be helpful in allowing us to avoid having to manually import the results of these scripts.
Hi Damian,
Thanks for bringing this to our attention. Currently, I don't believe this field shows up in NXT at all, so by extension it won't be in the API (which means it's also not in the Connector). I'll route this feedback to the team that owns this area to see what the plan is for this field.2 -
Hi Damian,
We will be making a firm commitment to pull in new items from our idea bank for API. Since this is a new field needed, I would encourage you to get that added so we can begin to track it with our other suggested items in that portal.
Anthony0
- 6 Blackbaud Community Help
- 33 Blackbaud Impact Edge™
- 19 PowerUp Challenges
