[Power BI] Data Gateway is showing error and not allowing to schedule refresh
I got the connector working, everything looks and works great. My issue is, when I publish to powerbi.com, I can access the dataset there but I can't schedule refresh. I followed the instructions on the github page, installed and connected data gateway personal, however the section to authorize on powerbi.com is not showing up. Instead I get this error:
"Unable to determine the data source due to unknown functions. When custom connectors are used, the error can happen if gateway doesn't have the extension enabled. Details: Query contains unknown function name: Blackbaud.Contents.
- Data source for Query1"
any luck with this? I am getting the same error message.
Any luck with this. I having the exact same issue
@Afif Abrar I am also running into this issue!
@Kelly Hogan
And I was able to fix it in desktop power bi in the settings as mentioned in another post! ?0 -
@Kelly Hogan Hi Kelly, I was wondering if you could please link to the post you mentioned that helped you solve the issue? I am having the same problem. I would really appreciate any help. Thanks!
@Steve Cyra Hi Steve! I have NO idea what solution I used to fix this issue since it was so long ago. But i must have just searched the community for the error. Sorry I couldn't be more helpful!
In case you didn't already have this resource….I set my gateway up using @Matt Thacker's demonstration at one of the user group meetings.
Here’s the link to his presentation:
Power BI User Group Monthly Meet-up - Blackbaud Community –
When I set up my gateway, there were some changes as to where things are located (settings and such), so it may take some hunting around the newer user interface.0 -
@Hallie Guiseppe thank you so much!
- 6 Blackbaud Community Help
- 33 Blackbaud Impact Edge™
- 19 PowerUp Challenges
