How do I edit a discount from the TeamRaiser application?
If you need to modify a discount – to change the percentage, alter the total number of discounts available, change the expiration date, etc. – proceed as follows:
1. On the Registration page for your TeamRaiser, click the Edit icon beside the name of your Participation Type. The page where you configured the participation type will re-open.
2. In the Discounts section of the configuration page, click Edit in the Action column beside the Name of the discount that you would like to modify to open the first configuration screen for that discount.
3. Use the Steps menu at the left of the screen to go directly to the section that you would like to modify (for example, click on Options).
4. Make your changes.
5. Click Save at the bottom of the page(s) that you modify to complete your changes.
6. If you would like to return to the configuration page for the Participation Type, click on the last page in the Steps menu and then click Finish or click Cancel at any time.
Note: All discounts can also be modified from the Discounts application.
For more information on this, please see the Help file within Convio.
