Engineer in Training - Ducks Unlimited Inc., Garfield, MN
Engineer in Training - Garfield, MN
Full-Time
Salary Range:$20.00 To 40.00 Hourly
Are you a skilled Engineer with a passion for the outdoors? Do you want to work for a leader in wetland conservation and make a difference in the world? Ducks Unlimited is currently seeking a talented Engineer in Training (EIT) to join our team in the Living Lakes Field Office, located in Garfield, MN.
As an EIT at Ducks Unlimited, you will work on a variety of wetland and habitat restoration projects, collaborating with a team of biologists, engineers, and construction managers to bring projects to life. You will be responsible for creating accurate and detailed design drawings for wetland restoration projects.
Ducks Unlimited, Inc., the world’s leading wetland and waterfowl conservation organization, is seeking a self- motivated, experienced civil engineer to be located in Garfield, MN. The successful applicant will join a highly motivated conservation team of biologists and engineers who are responsible for the planning, design and construction of wetland restoration and enhancement projects. Primary responsibilities will be in Minnesota.
Qualifications
Candidates must have at minimum, a B.S in Civil Engineering or an equivalent degree from an EAC/ABET accredited engineering program, and a preferred minimum of 2 years’ experience in civil engineering design. It is preferred that the candidate is a registered EIT or PE. Desirable qualifications include experience with Civil3D, hydrology, hydraulics, civil design including structures and pump stations, erosion control, construction inspection and project management. Demonstrated oral, written and interpersonal communication skills are essential. Candidates must be self-motivated, goal oriented and able to work with and solve problems in close team-based relationships.
Responsibilities
Engineers perform a full range of project planning, design, contracting, and construction management functions on wetland, riparian, and associated habitat restoration projects. Project delivery responsibilities include field survey, engineering design, drafting with AutoCAD Civil 3D, project bidding, field inspection, and construction management. A close working relationship with local, state and federal personnel, private landowners, and other conservation partners will be an important aspect of the job. The position will include travel throughout Minnesota.
Specific duties include:
- Survey project sites using Trimble GPS survey equipment.
- Interpret, select, adapt, and apply engineering, surveying, and construction management principles and practices across a range of engineering services within a diverse conservation program.
- Complete engineering designs and reports as required.
- Draft engineering plan sets using AutoCAD Civil 3D software.
- Conduct field inspection and perform construction management oversight as needed.
- Ensure that consultants and contractors adhere to project plans, specifications, and schedules.
- Act as contracting officer, ensure contract compliance and manage project budgets.
- Perform field work as required which could include strenuous outdoor activity in difficult environmental conditions. Must be able to operate ATV and outboard boat when necessary.
To apply please go to https://workforcenow.adp.com/mascsr/default/mdf/recruitment/recruitment.html?cid=7deee1c0-b159-4fdc-8bdb-3f1d87c47510&ccId=19000101_000001&jobId=467068&lang=en_USand fill out the application materials. For further information regarding this position, please contact, Jordan Lillemon, PO Box 177, Garfield, MN 56332.
Email: jlillemon@ducks.org
DUCKS UNLIMITED, INC. IS AN EQUAL OPPORTUNITY EMPLOYER
It is the policy of Ducks Unlimited, Inc. to afford equal employment opportunity to all qualified persons regardless of race, color, religion, gender, national origin, military status, disability, age, or genetic information except where age or gender is a bona fide occupational qualification as allowed by the Civil Rights Act of 1964. It is the policy of Ducks Unlimited, Inc. to afford equal employment opportunity to all qualified persons regardless of race, color, religion, creed, national origin, ancestry, sex (including pregnancy, childbirth, lactation and related medical conditions), sexual orientation, gender, gender identity, gender expression, age (40 or over), disability (physical, mental or visual), genetic information, marital status (including registered domestic partnership status), military and veteran status, immigration status, or any other category protected by federal, state or local law.
