Adding Tracking Pixel to One Form
Hi all. Anyone have a solution to adding a pixel to just one donation form in Luminate? BB gave use the suggestion of putting it in the pagewrapper but we use the same pagewrapper for all our forms so that won't work. If there is a workaround that you know of, I'd love to hear it!
@Nikki Dale You could make a copy of the one pagewrapper you use for all of your forms, update the pixel in the copied pagewrapper, and then use that copied pagewrapper for your donation form. That's the simplest approach I can think of.
@Erik Leaver Thank you, Erik! We ended up going that route. Appreciate your response!
@Nikki Dale
Side note, another approach if it's just the one form is to add a caption with your code in it. You can do javascript, images, or whatever else you need there.0
