How do I provide confirmation to Google that I own my site?
Google has a site verification process outlined here:
The "Upload an HTML file" option will not work with Convio due to the way that Convio handles page not found problems. As such you will need to add the meta tag that Google will provide instead. The easiest way to do this is:
1) Find and edit all of your PageWrappers in the PageWrapper Editor.
2) Go to step "2. Meta Tags".
3) Find the section labeled "Additional HTML Tags for HEAD Element".
4) Put the meta tag there and save. The meta tag should look something like this:
<meta name="verify-v1" content="kz0IN0OUqfEYRpyZI5LoFvshnRUz8yB1T35lbuc6jw4=" />
This meta tag will be unique to each request for verification so be sure to get yours from Google's site.
If you have multiple PageWrappers, you might consider putting the meta tag into a reusable PageBuilder page and using that in step 2 instead. This technique will allow you to more easily correct and/or update the meta tag when needed.
