Donation Form Giving Levels
Is there a way to right align custom giving amounts in the net community?
This is not easily editable on my end and I don't want to hire a programmer.
  • April Frazier:
    Hi April! I see this was posted a little while ago. Were you able to customize your form in the way you wanted? Sometimes providing screenshots will allow community members to get a better idea of how to help. :) If you're still having trouble, would you mind posting screenshots so that we can see what you're working with?
  • 6ddd8c56f1e9104f6dce46eccd54356e-huge-do
    Here is a pic.  Also is there any way to have a form that adds mutliple items to a cart?
  • I know this is old, but I have the same questions so I thought I'd reply and see if anyone knows....
  • David Seager
    David Seager Blackbaud Employee
    Tenth Anniversary Facilitator 1 Name Dropper Blackbaud Partner
    Hi Jessica Thrift‍
    To answer your first question, the giving levels are aligned based on your site CSS. In this case you would need to hire a designer to make the changes you need to the site style sheet.
    As for the follow up question, you can enable multiple designations which would allow a user to add multiple donations to the same transactions as long as its a different fund. Based on your screenshot below even if this was accomplished you would not be able to decipher from the RE data if a user picked one "New Life Orientation" for $100 or two "Clothing For The Season" for $50 each/total $100. This is because the label is not transferred to Raiser's Edge, just the amount and the fund.
    If you would like to discuss this more I would suggest to contact Blackbaud Support at http://support.blackbaud.com/
    David
