Format problems in Gmail
When creating an email, the format goes all wonky in gmail, but looks fine in all other email programs.
I saw another question about this on here, but no answer.
Has anyone else encountered this? Any idea how to fix it?
  • hmm, our emails seems to be alright in gmail. although sometimes the test emails font changes to purple.
    are you having problems with spacing, alignment, or font?
  • I also have the same formatting problems in GMail. Some of the font is purple and some is black. I tried to go into the source code but it doesn't fix the formatting.
  • Gmail is very restrictive about CSS styles. If you're using stylesheets to control the layout and look of the text, you may have to use inline styles instead.
  • markstewart :
    CSS is indeed the likely culprit. As mark said, you should use inline styles, though even then you'll sometimes run into formatting discrepancies.  Trial and error is key here.
