Have they fixed issues with exporting ratings yet? I can't export NXT ratings in order
I want to export NXT ratings so I can compare apples to apples. End Goal: A spreadsheet for a committee to review that shows the person's name, assigned solicitor, Proposal, proposal ask & expected amount, the internal rating code we've created (under Proposals, Ratings) and the NXT Overall Wealth Rating.
The NXT ratings are jumbled in one column. For example, my first 2 results show Recommended Donor Type, and the next 1 shows Overall Wealth Rating. And since there are "A"s in each rating type, I can't tell which it's showing me.
I need to pull out in one column all the Overall Wealth Ratings. Then in another column I need to show the Recommended Donor Type. Ideally, I'd be able to individually pull over information for all the stats separately.
Thank you!
Amy Stubbings:
Hi all,
Thank you!I haven't noticed any change. I still have to do an export and export a query with the ratings and then use vlookup to get them into the exported data. It really sux.
It is possible to put the specific ratings into the ouput of a query in the order you want and then export the query. Not ideal and I agree that you should be able to do this in export.
