Query Problem - giving 15 years or more not necessarily consecutive
Eileen
Eileen, most often done by creating an export with summary field for each year, exported to excel and manually totals/manipulated there. Some info can be pulled using a pivot report. There have been a number of posts with a lot of detail on how to do this if you can search the forums. I'd try 'non or not consecutive years' 'X of Y years' 'consecutive years' as search terms.
Export takes some time to set up as you'll need field for each year in your range. You can use all records or create a query of donors who've given durig a certain time and could add a filter for at least X # of gifts.0 -
JoAnn Strommen:
Export takes some time to set up as you'll need field for each year in your range. You can use all records or create a query of donors who've given durig a certain time and could add a filter for at least X # of gifts.Thanks JoAnn. I was kind of afraid that the answer would be setting up the export with fields for each year. I will first try a search as suggested to see if anything different comes up. But I believe will just have to set aside some quiet time and get it done. I appreciate your help.
I've found that an export like this while cumbersome to build is a useful one to have. I keep a template for one that I copy and save each year and just change the dates to include the current FY.
