Menu Part - using dropdown
I'm trying to add dropdown items into a Menu part but I need to apply a class to the drop down <ul> tag, this doesn't seem possible?
I'm hoping it is just Friday and I'm missing something obvious :) otherwise I'll just use a unformatted part.
In the following I can set mainNav from the Menu part style tab but I want to add a class on the ul where NC has set nccUlMenuSub1
<ul class="mainNav">
    <li class=" menuItem1 first parent">
        <a href="#">News and Events</a>
        <ul class="nccUlMenuSub1">
            <li class="menuItem1 first last"><a href="#">Events</a></li>
        </ul>
    </li>
    <li class=" menuItem2"><a href="#">Social</a></li>
    <li class=" menuItem3"><a href="#">Community</a></li></li>
</ul>
  • Hello Kerry, you can add a class to an element via JS and an unformatted text part. One of the following should work...
    Example 1: JS-only
    <script>
        var menu = document.getElementsByClassName('nccUlMenuSub1');
        menu.className += " otherclass";
    </script>
    Example 2: jQuery
    <script>
        $(document).ready(function(){
            $('.nccUlMenuSub1').addClass('otherclass');
    </script>
    Let me know if you're having issues once you add one of these scripts to an unformatted text part.
    Edit: And it probably goes without saying, replace "otherclass" with your desired class, keep the single quotes though.
    Chris
  • Thanks Chris, I think I've decided just to build the entire menu using unformatted part rather than introducing JS to fix it up afterwards as it will need a couple of other tweaks as well.
