How do you change field type from string to date
Hello!
I'm using Crystal Reports 10 and using a RE export to a CSV file that I'm then saving as an Excel 97-2003 file
One of the fields is a date but it is importing into CR as a string so I am unable to do the formating I want on it (I just want it to list month/year)
Any advice on this?
thanks!
Any advice on this?
thanks!
Use the Date function. Put the text string in parenthesis: Date (string)0
Chester Bammel:
Use the Date function. Put the text string in parenthesis: Date (string)Thanks for responding Chester but I do not understand what you mean, by using the date function.
The text needs to be parsed, converted into numbers and then formatted to a date data type. The following formula can be altered depending on how the YYYYMMDD is organized:
If Length ({TABLE.FIELD}) = 8 THEN
Date (Val ({TABLE.FIELD}[1 to 4]),
Val ({TABLE.FIELD}[5 to 6]),
Val ({TABLE.FIELD}[7 to 8]))0 -
Create a new formula. In the formula window, there are 3 sections - one of which is Functions. Expand the +, then expand the + next to Date and Time. There you will see the list of functions for date.
In the formula box, you can simply enter the text as follows: Date(your field name)
This is assuming your string is in a format that resembles a date. For instance: date (10/4/15).
You can verify by hitting the "Check" icon that looks like 'x-2' with a checkmark under it that is right below the Save and Close button.
Then, just drop that formula into your report.0 -
Thank you both! I did get it to work0
You’re very welcomed.
Chester
BammelBusiness
AnalystIT
Enterprise ServicesDivision of
Information TechnologySam
Houston State UniversityBox
2397 Huntsville, TX 77341Office - (936) 294-2351
