Creating a pop-up menu
Our main menu in Netcommunity is currently an unordered list menu. I'd like to create a version which acts as a popup menu (i.e. sub-level items display when the item above is hovered over); do I need to use a table-based menu for that?
I would like the design formatting of the popup menu to match that of the unordered list menu we are currently using - is there a quick way to duplicate the formatting?
I haven't used CSS before but am happy to learn if necessary
  • Hi Lucille,
    No you don't have to use a table based menu for creating a dropdown sub menu. Rather you can nest the secondary <ul> within that parent <li>
    <ul>
    <li>menu1</li>
    <ul>
    <li>submenu1</li>
    <li>submenu2</li>
    </ul>
    <li>menu2</li>
    </ul>
    Now there are plenty of tutorials on how to create a CSS based dropdown menu out there. Here's one:
    http://cssdeck.com/labs/another-simple-css3-dropdown-menu
    Hope it helps.
    regards,
    Daniel
