installing NetCommunity RE Plugin silently
Hi im installing Raisers Edge silently over our network and can get it installed fine.
However i also need to install NetCommunity RE Plugin\\plugin655patch5.exe
Does anyone have any idea how i can install this silently?
Please help!
this is the output of the installer when run manually
Command Line: "C:\\WINDOWS\\TEMP\\BB2161\\Installer\\bin\\Setup.exe" "Z:\\InstallFiles\\NetCommunity RE Plugin\\plugin655patch5.exe"
Running installer version: 6.55.526.5
Install Name:
Loading Step Blackbaud.Installer.UI.PluginOnly.InstallTypeControl. Step is skipped.
Loading Step Blackbaud.Installer.UI.PluginOnly.NewInstallControl. Step is skipped.
Loading Step Blackbaud.Installer.UI.PluginOnly.ConfirmControl. Step is shown.
Loading Step Blackbaud.Installer.UI.Common.ExecuteSequenceControl. Step is shown.
Starting installation process: Tue, 16 Dec 2014 13:34:58.7579
Install Name:
Install Type: NewInstall
TargetPath: C:\\Program Files (x86)\\Blackbaud
InfinitizeDatabase: False
IsIIS64Bit: False
IsPluginOnly: True
IsUK: True
ProductType: Generic
ClientID:
Feature Actions:
CRM: NoAction
Database: NoAction
EE7Plugin: NoAction
NetCommunity: NoAction
NetCommunityService: NoAction
PluginService: NoAction
RE7Plugin: Install
RE7WebService: NoAction
RPRE7WebService: NoAction
OnlineExpressPlugin: NoAction
About to execute target: EXTRACT_INSTALL_FILES
No patch file found.
Extracting C:\\WINDOWS\\TEMP\\BB2161\\Installer\\RE7...
Extracting C:\\WINDOWS\\TEMP\\BB2161\\Installer\\RE7\\Custom...
Extracting C:\\WINDOWS\\TEMP\\BB2161\\Installer\\RE7\\Custom\\Shelby...
Extracting C:\\WINDOWS\\TEMP\\BB2161\\Installer\\RE7\\DRE...
Process completed successfully.
About to execute target: DeployFiles
Build started.
Project "" (DeployFiles target(s)):
Building with tools version "2.0".
Target "DeployFiles" in project ""
Using "DeployFiles" task from assembly "C:\\WINDOWS\\TEMP\\BB2161\\Installer\\MSBuild\\Tasks\\Blackbaud.Web.Content.BuildTasks.dll".
Task "DeployFiles"
Copying folder from 'C:\\WINDOWS\\TEMP\\BB2161\\Installer\\RE7' to 'C:\\Program Files (x86)\\Blackbaud\\The Raisers Edge 7'...
Registering C:\\Program Files (x86)\\Blackbaud\\The Raisers Edge 7\\Custom\\Shelby\\BBNC_SCWrap.ocx
Registering C:\\Program Files (x86)\\Blackbaud\\The Raisers Edge 7\\Custom\\Shelby\\BBNCExtensions.dll
Registering C:\\Program Files (x86)\\Blackbaud\\The Raisers Edge 7\\Custom\\Shelby\\Blackbaud.Core.dll
Registering C:\\Program Files (x86)\\Blackbaud\\The Raisers Edge 7\\Custom\\Shelby\\Blackbaud.CoreUI.dll
Registering C:\\Program Files (x86)\\Blackbaud\\The Raisers Edge 7\\Custom\\Shelby\\RE7ShelbyPlugin.dll
Adding C:\\WINDOWS\\TEMP\\BB2161\\Installer\\Support\\Blackbaud.PIA.RE7.SecData7.dll to the GAC
Done executing task "DeployFiles".
Done building target "DeployFiles" in project "".
Done building project "".
Build succeeded.
About to execute target: UpdateARPEntry
Build started.
Project "" (UpdateARPEntry target(s)):
Target "UpdateARPEntry" in project ""
Using "AddARPEntry" task from assembly "C:\\WINDOWS\\TEMP\\BB2161\\Installer\\MSBuild\\Tasks\\Blackbaud.Web.Content.BuildTasks.dll".
Task "AddARPEntry"
Copying file from 'Z:\\InstallFiles\\NetCommunity RE Plugin\\plugin655patch5.exe' to 'C:\\Program Files (x86)\\Blackbaud\\uninstall.exe'...
Done executing task "AddARPEntry".
Done building target "UpdateARPEntry" in project "".
Build succeeded.
About to execute target: UPDATE_REGISTRY_INSTALL_INFO
Installation process completed: Tue, 16 Dec 2014 13:35:32.7259
Loading Step Blackbaud.Installer.UI.PluginOnly.CompleteControl. Step is shown.
