State Drop Down menu in the OLX set up form in RE
Can the State drop down menu in the Online Express set up be change to a free for text box?
Is this able to be customized for a specific organization? I can provide all the organization info when/if this is possible.
thank you
thank you
The state selection menu can not be free-hand, because it maps to your available entries in RE.
You can customize which states are available on the web by visiting the Integration options. Check the Account menu in the top right, then select Integration options, select the "General" section, and then the "State" tab.0
