OLX email marketing how to expand image full screen
Hi - I'm unable to find (if there is an option) other than in Style/Selected column style/spacing & alignment/padding set to 0, or by editing the image content/image display width/set width to max pixles; for the purpose of expanding the image to fit full screen so that when the email is received, there is no white space around the image, that it fills the entire space of the email. Thank you for any suggestions!
Hi Shannon...you pretty much got it right. If you have padding applied to any of the content "cells" then all content (both text and images) will be sized such that the chosen padding is preserved. So, to have an image fit to the edges of its containing cell, the padding in that cell has to be zero.
You should not have to manually set the pixel width of the image though to the width of the cell. If you choose the "Best Fit" image display width option (which you see when editing the properties of the inserted image), it will be sized to the edges of its container as long as the image itself is natively at least that wide.
If your image is natively narrower than the width of the content cell, OLX doesn't automatically "grow" the image larger than its native dimensions, because doing that can make for a lousy looking image (resolution-wise). But if your image width is pretty close to the width of the cell, you can manually enter that cell width in the image width properties box and it will expand to fit.
Hopefully that helps!0
