Mailing preference service & telephone preference service
We have created attributes for contact restrictions and contact types (what they want to receive) and have the staff members name and the date added with it. This allows us to see what type of contact they do and do not want. Our lists are quite granular and have been broken down into the different types of contact we do.0
I agree with Jody. A combination of attributes and solicit codes are the best way to track.0
We are currently just using the solicit code field, but have some very specific codes, such as "Solicit Once a Year" which to us means we only send them stuff at year end. I could easily envision attributes being a big help too though. It would be it's own category, and then I'd make it a table field, with the ability to add more into the comments area.0
Jody Johnson:
We have created attributes for contact restrictions and contact types (what they want to receive) and have the staff members name and the date added with it. This allows us to see what type of contact they do and do not want. Our lists are quite granular and have been broken down into the different types of contact we do.Hi Jody
Would it be possible to have a telephone call to speak to you about specifics? My direct dial is 01932-823103. Happy to call you if you let me know your contact details and preferred times.
We use solicit codes as well to filter our mailing lists.0
Elizabeth Grover:
I agree with Jody. A combination of attributes and solicit codes are the best way to track.I second the agreement - we primarily use attributes in our system to determine best ways to contact constituents.. We use BB's AddressFinder to annually refresh our addresses in the database.
The solicit code field is the best way I know of to do what you are asking.0
I've been meaning to reply to this for a while as I asked some similar questions here back in March (https://community.blackbaud.com/forums/viewtopic/147/15328) (Note to admins perhaps we could merge these?)
The Institute of Fundraising have responded to the report from the FRSB and the complaints and the media furore and whilst I wish they'd been a little more combative in their responses, it looks like the upshot of this is going to be that we're going to need to buy a live subscription to the TPS.
The money's not the real problem however, it's how to tie that info in with RE. The data's only live for a month, so a one off solicit code switch isn't going to be enough. Anyone got any ideas on practical ways to do this with RE?
One of the main complications is that your hime number can be on the TPS, but the mobile isn't, or vice versa. And, of course, that it's a constantly changing list.
I guess I need to look at at least a monthly pull off of all phone numbers, screen against the TPS and import/update of a solicit code / attribute, but I was wondering if anyone had found a good way to do this, or even, just to check, that people think the IoF's guidance means what I think it does as it also seems unclear.
Matt0 -
I actually just replied to Matt's original post (https://community.blackbaud.com/forums/viewtopic/147/15328 didn't realise it was from back in march oops!) specifically around recording TPS.
Regarding monthly updates, as we only do ad-hoc telephone fundraising, we would just do prior to each campaign, but you rais an interesting point - would a number on the TPS ever no longer be on the TPS in the future? Can't imagine someone actually asking to be removed from it, but perhaps a number gets removed if it is disconnected and re-allocated to another customer?
Mike0 -
The FAQ section on the TPS website states:
if you change your telephone package, obtained broadband or change telephone line service provider for example, we may receive notice from your current/old line service provider that your line has been made inactive. In this case your number would be removed from the file as the service is only intended for live numbers.
Alan French:
The FAQ section on the TPS website states:if you change your telephone package, obtained broadband or change telephone line service provider for example, we may receive notice from your current/old line service provider that your line has been made inactive. In this case your number would be removed from the file as the service is only intended for live numbers.
I guess there is also the issue of if you then get an opt-in from the constituent at some stage so that you can then still telephone them.
Matt
