Querying Spouse Attributes
I am trying to query for non-constituent spouses who share a specific attribute using this criterion: Spouse>Specific Attributes>Specific Attribute “X” Description equals “Yes”
I am getting 0 results, when I know for a fact that there are spouses with the attribute on their records. Is there something else I need to enter in the criteria section? Something that needs to be done in the spouse (or the primary constituent) record?
It worked for me just now, to do exactly what you posted, in both a constituent type and gift type query. What query type are you in when it's not working? Are you pulling the Yes value from a table or from typing it in? If you are typing it, have you verified that it's actually "Yes" and not just "Y" or something else?0
Hi Heather - Thanks for the reply. I was using a Constituent query. I just tried a Gift query, and it didn't work there either. The "Yes" value is from a table (if I'm understanding the meaning of "table" correctly in this context). The attribute data type is set as "Yes/No."0
How are you determining non-constituent spouses? Try removing the Attribute criteria (and from the output) and see if you get any results.
You may have to find these non-constituent spouses through individual relationships instead of the Spouse criteria (Relationships > Individuals > This Individual is A Constituent = No; This Individual Is The Spouse = Yes; plus the Relationship attribute criteria) .0 -
That did the trick, John Heizer--thank you so much!0
I wonder if I misunderstood your "non-constituent" reference? Do you mean they are actually entered as non-constituents or are only a spousal record within a primary constituent record? I've never had to do what was suggested by John, and I'm glad it worked for you, but I am curious to see if we were speaking about something different than each other.0
Heather MacKenzie:
I wonder if I misunderstood your "non-constituent" reference? Do you mean they are actually entered as non-constituents or are only a spousal record within a primary constituent record? I've never had to do what was suggested by John, and I'm glad it worked for you, but I am curious to see if we were speaking about something different than each other.Those two things are identical. It's just that the Spouse non-constituent gets a special flag that puts it under the Spouse button on Bio1.0
