Question/Concern with Tribute Query
I am having trouble running my Tribute query. I have used this query many times and now it is not pulling the tribute gifts. Anyone having the same problem?
Anonymous Blackbaud User:
Don't have the tribute module, but will ask the question of the month when it comes to something not working: Did you update / Were you recently updated as a hosted RE to 7.94? If you read recent posts that seems to have caused various issues with some reports. Don't know about queries but perhaps because Tributes is a separate module... ????
Do you mean the tribute report? I'm not aware of a tribute query. If you are using the query, please list your parameters and output fields and I'll see if I can get similar results.
That said, we ran a couple of tribute reports this morning here with no problems, and we are hosted using 7.94, so I've seen no problem in functionality there.
I have at times had problems with records not showing up in the query. But usually when I go to the missing record and I can see that something wasn't entered correctly. If you've been using this query without problems, I'd check the missing records for errors.
