Overflow Error Message in Gift Batch Entry
When our gift entry staff member goes to commit a gift batch, recently an error message pops up saying "Overflow." The gifts post to the appropriate records and are pulled in reports, but there is not query made from gift batch. Not sure what is going on or how to fix it. It started a month ago and is now happening more frequently. Any help would be great. Thanks
K. Becker:
When our gift entry staff member goes to commit a gift batch, recently an error message pops up saying "Overflow." The gifts post to the appropriate records and are pulled in reports, but there is not query made from gift batch. Not sure what is going on or how to fix it. It started a month ago and is now happening more frequently. Any help would be great. ThanksHave you checked the knowledgebase for info on your exact error? Don't know if this is the correct solution, but it's one of several in knowledgebase. I'd check their first, then for error issues, I'd check with support.
Solution ID:BB322641 Product:The Raiser's Edge 7 Published:01/04/2007 Updated:08/14/2012 Description
When saving a batch, you receive the error "Overflow." The error occurs for one user on one workstation.Environment
Answer
Edit the registry and rename the REINI_1 key under HKEY_Current_USER\\Software\\Blackbaud\\REIni_1. Name it OLD_REINI_1.
Note: Incorrect changes to registry settings can cause serious system problems that may be irreversible without reinstallation of the operating system. You must back up your registry before making any registry changes. We are not responsible for damage resulting from incorrect use of the Registry Editor.
